What simple sampler for play oneshots in Hostprogram (Mac)
Author What simple sampler for play oneshots in Hostprogram (Mac)
Funky40
(I´m on Mac....)
Hi, i need a (simple) sampler to load one shot samples/phrases into my Host programm,
so that i can play mostly recorded phrases thru my desired FX chains.
i have kontakt 11 ( or 10), but don´t like the NI UI/GUI. never used Battery or so.
What would be your choice of a Sampler if its just to play some phrases as one shots thru FX ?
what to look at ?
(well, pitch, loop-on/off, loop start&end point, would be welcome to have as adjustable parameters)
Zon
TAL sampler thumbs up
Funky40
yeah, the TAL i see mentioned quite often. Need to check !
for now i jumped over my own shadow and begun to use the NI Battery.
Probably the first NI software that i found very inspirational in use......and also in regards to file handling etc.
I definitly like it for drums, ...for more creative uses do i still struggle.
to just have some few longer samples at disposal to trigger those, looped or not, is it doing it for now
i´ll check the TAL now definitly.
Thanks Zon
sduck
Maybe Farrago? https://rogueamoeba.com/farrago/ - I don't know if it'll work for your specific situation though.
Funky40
No, has to be a AU device in this case.
But good to know that this exist wink
martinjuenke
Why not import into Logic? Very comfortable to prehear and import into a track, time stretch, pitch shift and so on....
