LxD closest alternatives in the same price range
Author LxD closest alternatives in the same price range
Andy137
There's no LxD or Optomix these weeks. Will them back to the market? Or better to take a look at the alternative modules. I'm more interested in LxD and its alternatives. Menq Qi DPLPG or Doepfer A-101-2? What will I lose in sounds versality or tone palette if I buy one of these two modules comparing to the LxD preferences?
mosorensen
LxD appears to be in stock at Signal Sounds.
hawkfuzz
There’s a great lpg comparison video on YT that will give you an idea.
lud
Often see both second hand too
Bignorthumbrian
I have the LxD, Optomix, Meng Qi, Takaab DLPG and the Doepfer 101-2.
The Meng Qi has a different sound to the LxD, the Takaab has very long decay on each output. Optomix sounds great, and has plenty of options. The Doepfer is a filter, vca and LPG, and is a lovely filter and fantastic value for the money. My favourite is probably the LxD, especially when you have the two lpgs linked in series as a vca.
The Junglechrist
The LxD has indeed something special to it that I like a lot even tho I have tons of lpgs (optomix, QMMG, Verbos ATC, Dynamix if it applies and a Dual Borg on sale). It very simple and sound good almost all the time.
The bottom section is very « sweet ».
rew_
https://wigglehunt.com/#/search?query=lxd&stock_status=1&condition=&pr ice_min=0&price_max=5000&base_currency=
j_dowe
https://reverb.com/p/make-noise-lxd-lo-strike-duo-low-pass-gate-module
i love my LxD!
Blairio
I have an Optomix mk1, and two Doepfer A101-2's.
The Doepfer unit is very flexible, As another posted noted, it can be a straight 12db low pass filter, or a VCA, or a LPG. So when you don't need a LPG, you have a spare VCA or filter. The Vactrols in my two are what I would call 'medium' length decay, whereas on my Optomix, one the two channel's Vactrols has a sort decay, and the other a longish one!
I don't think you would be disappointed with either unit.
I suggest (if possible) trying out low pass gate modules in your local shop, because there does seem to be a lot of variability in Vactrols - even between examples of the same model of LPG from the same manufacturer.
dumbledog
Just gimme an LxD with two 6dB sections already.
hawkfuzz
I want this as well
wm.wragg
Yeah I love the 6dB section, so sweet.
Blicken Synths
Haven't tried the lxd but I'll second what everyone says about the A-101-2 being excellent. Using it a lot lately for both lpg and vca functions. I must try it out as a filter
blakeq
There is a Pittsburgh lpg module as well, maybe only available used
And don’t forget mutable streams!
pugix
This is why I have two LxDs.
moremagic
i traded a pule of unracked utilities for an odyssey last year but ive still got my lxd on the shelf taunting me to get another case
