2.4inch TFT MCUFriends shield display hard reset mandatory
Author 2.4inch TFT MCUFriends shield display hard reset mandatory
Gibran
Hello guys.
I´m developing a new module with this display.
The problem is: every time the board starts I need to press the display reset button to work properly.
Even the board is UNO / MEGA / DUE.
Even the sketch is the library example or my code.
Even if the board is connected to USB or Vin
Even a delayed software reset.
the problem remains. The graphics are a mess.
This is not the known "white screen" problem (This one was solved already)
I had to make a delayed hardware reset.
The module starts and the delayed reset circuit do the job. It worked but , this is an ulgy solution.
Anyone had this problem?
Thank you very much !!
