Help with 16 step sequencer
Author Help with 16 step sequencer
stepbysteps
16 step sequencer usb
Hi,
I can't find any circuit diagram online to make my sequencer.
Can someone help me with this project?
There are similar ones online but this one is a little different
here are some details:
little plastic unit with 10 pads to trigger sounds, 16 lights+switches for the sequencing (tr808 style
Are the best),
You press a designated pad and then place it in the sequence by pressing the 16 bottoms switches.
there must be a stop and play button and a tempo adjustment wheel.
Connected by usb for power and to send numbers to the computers (No midi no notes here).
So it's very basic, but I want the unit's pads to send out numbers from zero to nine,
and the sequencer must also send out numbers.
It's basically going to trigger samples on an app on my computer.
A numerical keypad can be used to replace the pads if it makes things easier
A raspberry pi or Arduino can be used to make things easier or less soldering
thank you!
View appearance:
[img]http://v.ht/6zvL[/img]
MapacheRaper
Arduino nano is your best bet. Quite easy to work with, powerful enought to run that.
You can look a look mum no computer, he has a similar secuencer to that one.
Jaytee
It’s not exactly clear what you’re asking of us?
nigel
If it's just going to send numbers to a computer to trigger samples, why not use Midi? That should give you a lot of example circuits (and code) to work from.
