4MS DLD 'DJ style transitions' patch examples.
brandonlogic
Post by brandonlogic » Sun Feb 10, 2019 12:42 pm
R.U.Nuts wrote:
Silentnotes wrote: That seems odd. How can the timing be tight if you are not hitting Hold on the beat?
Because the delay time is synced and the delay is constantly looping in sync. Hitting the hold button offbeat does neither affect the delay time nor does it shift the recorded loop out of phase. Hold only prevents the delay from recording new material into it's buffer and from erasing the recording that was present in the buffer at the moment you hit hold.
Exactly :yay:
Silentnotes
Post by Silentnotes » Sun Feb 10, 2019 1:25 pm
Exactly :yay:
Oh ok, I get it. Thanks guys. What is Quantized Hold good for then? I cant think of any other case..
Rupert the not so great
Post by Rupert the not so great » Sun Feb 10, 2019 2:56 pm
Thanks for the info guys! Im gonna try it all out tonight. I'll try clocking the DLD with a 4/4 trigger from the BSP. Not sure why I never thought of that.. Hopefully it works.
As far as clocking goes.. do I need to clock only the 'PING' or do I need to clock 'loop A' and 'loop B' as well?
:despair:
R.U.Nuts
Post by R.U.Nuts » Sun Feb 10, 2019 4:31 pm
Silentnotes wrote:
Exactly :yay:
Three use cases I can think of:
1.: If you want to replace only a section of a loop with a new recording. For example, you recorded a 16 step loop and want to replace the last four steps of that loop with something else.
2.: If you have feedback turned up higher in order to record an overdub. For example you have a loop recorded and hold enabled. now you turn up the feedback so once you disengage hold, a second recording is dubbed over the old one. In this case it's important to keep hold disengaged for exactly the lenght of the loop because if hold is disengaged for shorter you obviously won't record an overdub over the entire lenght of the loop. On the other hand if you disengage hold for longer than one roundtrip of the loop, you'll add a third overdub as soon as the loop has finished it's cycle.
3. If you want to record a loop wich is shorter or longer than the sequence you're recording. For example you have a 16 step sequence running and you have set the DLD's delay time to three steps to record an exact slice of three steps from that sequence.
R.U.Nuts
Post by R.U.Nuts » Sun Feb 10, 2019 4:39 pm
:despair:
Loop A and B are clock outputs not inputs :hihi: They spit out a gate that syncs to the delay time of the corresponding channel. Don't wanna sound rude but have you read the manual?
sillyquestions?
Post by sillyquestions? » Sun Feb 10, 2019 4:58 pm
Not rude at all. I appreciate the reply. I've read it three times now in two days. Getting there a little but i've learned more asking on here. Some people connect with a manual, I don't.
In saying that, it's definetly one of the better ones ive read. IMO.
Post by Rupert the not so great » Sun Feb 10, 2019 5:11 pm
wooops! I never signed my bro out on that one ^ that's me btw :yay: :guinness:
hawkfuzz
Post by hawkfuzz » Sun Feb 10, 2019 5:45 pm
sillyquestions? wrote:Not rude at all. I appreciate the reply. I've read it three times now in two days. Getting there a little but i've learned more asking on here. Some people connect with a manual, I don't.
Reading the manual doesn’t really help in most cases. You are supposed to play with the functions as you read them. It’s not instant but it’s how you end up understanding what your module can and cannot do and maximize your system.
Mashmore
Post by Mashmore » Sun Feb 10, 2019 6:02 pm
Rupert the not so great wrote:Thanks for the info guys! Im gonna try it all out tonight. I'll try clocking the DLD with a 4/4 trigger from the BSP. Not sure why I never thought of that.. Hopefully it works.
:despair:
Clocking the ping input clocks a and b. The time knobs and switches do the rest.
brandonlogic
Post by brandonlogic » Sun Feb 10, 2019 6:14 pm
As a seasoned DLD user, I honestly never even tried this specific use of the DLD before I made the video for this thread. I am pleselty surprised by the results. It really is a perfect module for this application IMO. I am going to incorporate this into my next solo live performace. Perfect transitional tool. So much more interesting than just a hard cut pattern change. If you have headphones you could even cue up the next pattern and make all kinds of changes to a patch before and preview it in the headphones before making the transition. Such a useful live performace tool.
DLD is seriously once of my favorite euro modules.
Essential euro module for any system IMo. If I could only have one delay module in my rack, it would be this one.
Post by Rupert the not so great » Sun Feb 10, 2019 6:23 pm
From what I seen with brandonlogic's video it's exactly what I bought the module for. Im looking forward to trying all this out tomorrow. Im now thinking the 4MS PEG could be a great addition also... but thats me just catching the bug right?... :roll:
Thanks for all the inputs people. It's much appreciated. :bananaguitar:
brandonlogic
Post by brandonlogic » Sun Feb 10, 2019 6:26 pm
Rupert the not so great wrote:From what I seen with brandonlogic's video it's exactly what I bought the module for. Im looking forward to trying all this out tomorrow. Im now thinking the 4MS PEG could be a great addition also... but thats me just catching the bug right?... :roll:
:sb: :sb: :sb:
sharkminusbear
Post by sharkminusbear » Mon Feb 11, 2019 9:51 am
Great tips! I hadn't thought about using it to loop and crossfade like this and it really does work well. It's also fun to mess with the windowing of the loop while holding the button and then switch back to the dry signal.
Portal
Post by Portal » Fri Dec 13, 2019 3:53 pm
*edit figured out problem
