Controller to modular and iPhone at same time?
Author Controller to modular and iPhone at same time?
JES
Greetings everyone. Is anyone using a keyboard, step sequencer, or other controller to control both their modular and their iPhone at the same time? I’d like to hook my Linnstrument to play sounds out of an iPhone and at the same time control a couple sounds in a 3U case.
Doublecoolbossman
endorphin.es shuttle control, and the midi flow app.
Linnstrument into shuttle, iPad into shuttle, set up things in the app.
JES
Just updating this in case anyone needs it. Don't have a Shuttle control but it looks like it works.
Here are the options as of 2019:
Connect iPhone to a Hub using camera connection kit. Provide power.
Linnstrument into FH-2, set to forward MIDI to USB-C port, Fh-2 MIDI out into iPhone, use AUM or other app to filter channels to control different sounds with different settings from Linnstrument.
Linnstrument into iPhone, AUM MIDI routing into FH-2, ditto on MIDI filtering
iConnectivity Audio 4+ as a hub
