AC Encoder - gate stops working with Logic?
Moderators: Kent, os
cliffman
Post by cliffman » Tue Sep 07, 2010 4:22 pm
I am having an odd problem with the combination of Logic/VC/AC encoder.
Problem is:
After some period of time, the Gate output just stops working.
In the channel strip which contains AC encoder, I no longer see output.
If I use the matrix and send some other signal to that channel
(such as Env 1) , it appears to work. If i use the matrix and switch the
channels on the CV and gate, CV works, no gate.
I've made the gate return once by removing and re-installing AC encoder.
Nothing else so far has worked.
I think this is some artifact of the Logic setup rather than a Silent Way bug, so curious if any other Logic users have seen this.
Post by os » Wed Sep 08, 2010 8:33 am
As in, the gate stops working for new notes? Or, the gate stops if you hold a note down for a very long time?
cliffman
Post by cliffman » Wed Sep 08, 2010 4:22 pm
The gate stops for new notes. In the logic setup, I have the VC in a channel with output set to channel 7-8 of my interface, with the AC Encoder in the output channel.
So, when it's working, I see the gate signal in the VC channel, and in the output channel meters.
When it fails, i see the gate on the VC channel meters, but not on the output channel meters.
If I map Env 1 to output 2 in the matrix, i see signal on both the channel and output channel meters.
Post by os » Fri Sep 10, 2010 2:31 am
When it stops working, does the VC's panic button help?
cliffman
Post by cliffman » Fri Sep 10, 2010 2:56 am
No, the panic button does not help.
Post by os » Tue Sep 14, 2010 10:04 am
I'm out of ideas.
So the AC Encoder is swallowing the signal and passing nothing through? Or is the signal disappearing elsewhere?
Return to “Expert Sleepers”
