FH-2 Screen Protector fell out?
Author FH-2 Screen Protector fell out?
JES
It looks like the little protector that goes over the screen on the FH-2 fell out. I can put it back in but it slides around and falls out again.
Is there an easy way to reattach it? (I'm not handy so assume I'm a beginner if you are handy.)
Or can I just use the FH-2 without it? Or is there a risk to the screen or insides without the little protector?
It's purely there for protection. You can use it without it if you don't plan to e.g. drop something onto the display.
The window is intended to be glued to the front panel. You can glue it back on yourself, with the tiniest dab of adhesive.
