Running ES-8 on a usb hub
Author Running ES-8 on a usb hub
Dragonaut
Hello, I was wondering if running the Es-8 off a usb hub would be recommended. I’ve heard that soundcards don’t like to be run off hubs but I’ve run out of ports. Also: the Silent Way LFO has a quadrature mode but only two LFOs. How would I go about achieving quadrature? Thanks!
In my experience the ES-8 is happy on a hub. It probably depends what else is on the hub - more than one audio interface on the same hub might be pushing your luck.
Using the LFOs in transport-locked mode is an easy way to get any number at the same rate but different phases.
Dragonaut
Awesome. Thanks for the quick response.
