Hermod locks up when Octatrack sends transport signal
Author Hermod locks up when Octatrack sends transport signal
slentthndr
I'm trying to integrate Hermod with Octatrack. I want to be able to clock sync the two devices so I can have each running with its own sequence (but, like, tempo synced). That should be easy, right? I'm running into all sorts of problems.
If Octatrack is master clock (Hermod set to Clock = MIDI In), and OT is set to send transport controls (play/stop), the Hermod locks up and needs to be rebooted as soon as I try to switch sequences on the Hermod. If OT is set to NOT send trasnport controls, I can't get Hermod to start playing. I even tried using the new CV transport functions on Hermod to get it started when OT is master clock but not sending transport, BUT unfortunately, those CV transport featuers seem to only work when Clock = Internal.
PLZ HELP
oscilloscope
You'll probably get a better answer by posting your question in the Squarp forum.
https://squarp.community/
