Plague Bearer V3 IC
Author Plague Bearer V3 IC
maaaks
Hello,
I just plugged in my V3 plague bearer, only to smell a horrible smell and find a non working module. On inspection the IC looks to have a burn scar and a crack down one side. Does that just happen sometimes? I hadn't plugged in in wrong...
Anyway, does anyone know what the IC is? On the V4 version it uses a TL082 but this one seems to be different - can anyone make it out?
Thanks,
Max.
synthetek
Its a TL082 it says 082 on it just doesn't have the full part name on it.
NeolithicElectrophones
You soldered the IC backwards. The beveled edge needs to match up with the line on the pcb that goes through the legs. In the future a continuity test on the power pins will show you if anything is shorted before you plug it in.
synthetek
Its not backwards
maaaks
Thank you! You're right of course, d'oh!
This unit was not diy'd, but I figured I try to repair it.
