[AVAILABLE] fuzzbucket delay/fuzz euro SMT 8hp
Author [AVAILABLE] fuzzbucket delay/fuzz euro SMT 8hp
synthcube
Winner of the synthCube 2018 Module Design Competition
Congratulations to Nathan Fraser and his collaborators we're not worthy
fuzzbucket is an 8HP eurorack fuzz and delay module made up of a two transistor fuzz circuit and an MN3005 bucket brigade delay (BBD). Unlike most delay implementations which aim to mask sampling and reconstruction error, the Fuzz Bucket provides direct unfiltered access to delay line inputs and outputs as well as override of the BBD clock. All of the aliasing, distortion, and clock noise peculiar to bucket brigade delay is celebrated as a primary effect instead of being hidden away as an unwanted problem. In addition, a silicon "fuzz face" is grafted onto one of the audio inputs, to add some extra colour.
DIY-friendly SMT design, approximately 75 parts total
We are offering the black magpie panel version, with the grayscale aluminum version coming soon!
please feel free to use this thread for build notes, comments, questions etc
here's the link to the store:
fuzzbucket
the original Contest thread is referenced here: https://www.muffwiggler.com/forum/viewtopic.php?t=200914&highlight=
early video demo: https://www.youtube.com/watch?v=0GZoghWG4pU
teebeehex
This looks like a fun project. Fuzz + BBD delay + artifacts = some sweet noise nirvana.
Email sent smile
synthcube
we're also happy to say that we'll have the grayscale aluminum panels coming out within a few weeks for the fuzzbucket-- we love what Wes did with the design for this one!
teebeehex
I've prepared a Mouser cart for this, although there are a number of out-of-stocks with the 'global component shortage' currently.
https://au.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=ddbce 8cd5f
Also attached is a sheet with detail for sourcing the remaining components on the BOM.
synthcube
thanks for doing this! generally, passive components with similar specs as the BOM parts are sufficient-- for example 1% tolerance resistors, etc...
just to mention it, this module is designed around the xVive MN3005 IC. We do have a small stash of original NOS MN3005 in case anyone is curious about how those do in the module vs the xVive ones.
Markthom
I built this at the weekend and it's a bit of a wild animal grin
A bit of experimentation found that it can be tamed - the bass in the track below passes though the "clean" side and im tweaking the level of the "fuzz" side of the circuit throughout, bringing in snippits of distortion....fun!
https://soundcloud.com/mark-thomson-361900042/motorik-feat-performer-s equencer-instruo-csl-fuzzbucket-delay
[s]https://soundcloud.com/mark-thomson-361900042/motorik-feat-performe r-sequencer-instruo-csl-fuzzbucket-delay[/s]
synthcube
fantastic!
thetwlo
looks great! what does it sound like? can't find any demos of it, aside from the one above which doesn't sound like the description, seems very tame.
ndf
Below are some links to some raw sample sounds. The output has been recorded directly so the clock noise can get pretty tiring, sorry.
In the first two examples, no input is connected. The unit is adjusted to self-oscillate at three different rates from high (short delay time) to low (longer delay time), by increasing the level of the A or B input volume.
Feedback via input B: http://metarace.com.au/fuzzbucket/fbeg_cleanfb.mp3
Feedback via input A with Fuzz: http://metarace.com.au/fuzzbucket/fbeg_dirtyfb
.mp3
In the rest of the samples, an input (dry) signal is recorded to the left channel and the module output (wet) signal is recorded to the right channel.
A large input signal modulates a delay line in full feedback oscillation:
http://metarace.com.au/fuzzbucket/fbeg_fbsatinput.mp3
A slowly varying pan pulse signal interacts with a full feedback oscillation:
http://metarace.com.au/fuzzbucket/fbeg_fullfbpanpulse.mp3
Some sample and hold bleeps aliased, echoed and distorted:
http://metarace.com.au/fuzzbucket/fbeg_sandh.mp3
Organ pad played into delay line with tuned clock speed. Clock is very slightly de-tuned and feedback added.
http://metarace.com.au/fuzzbucket/fbeg_tunedclock.mp3
Playing a dorky sequence into the BBD clock.
http://metarace.com.au/fuzzbucket/fbeg_dseq.mp3
