The best way to connect Rosie to Babyface
Author The best way to connect Rosie to Babyface
Fou_Roi
Hello!
I have Rosie output module with stereo TRS line out and RME Babyface. What will be the best way to connect them for recording?
I have RCA to ADAT converter. For example I can try to get TRS-RCA cable and to connect Rosie through converter to the ADAT input on Babyface. But will it work?
Or I can get TRS-2 XLR cable and connect Rosie to Babyface XLR inputs and it will be a stereo signal which is preferably. But will the sound quality be good?
Maybe there are any better variants? Connecting through di-box, etc?
By the way just curious for future. If I will upgrade to Babyface Pro will it be the ideal variant to connect Roise to TRS in 3 and in 4?
Nagasaki45
TRS to 2 (unbalanced) XLRs should do the trick. No need to go through a different ADAT converter unless you are looking for some exceptional audio quality, your ADAT converter is super good, and the babyface is not enough. this is probably not the case though.
