Cirklon sync
Author Cirklon sync
Jaypee
Hello!
Sorry, I'm a bit lost with all these (great) modules.
I use an ES-3 and ES-6.
I need to clock a Cirklon using its DIN SYNC IN.
So, I need something to convert gates to din sync.
What is the easiest way to do it? Should I buy a ESx-8MD? Or is the cable adaptater enough? Sorry I never used midi/din sync before!
Cheers!
J.
You can use SW Sync to generate the two signals required (clock and run/stop). You just need an adaptor cable from the ES-3. ALM make one.
https://www.thonk.co.uk/shop/alm-dinsnyc-adapator/
Jaypee
I just realised it's a DIN SYNC OUT on Cirklon d'oh! d'oh!
However, Usamo should do the job properly.
Or any eurorack version of it?
Remember I have an ES-3 and ES-6
You can use an ES-5, plus either the DJ-1000 MIDI adaptor cable, or the ESX-8MD.
Jaypee
I'm confused with that DJ-1000 MIDI cable.
Why do I have to use as ES-5? Can't I use directly my ES-3?
Plus, how can 1 mono cable (DJ-1000 MIDI) can deal with start and stop signals?
Sorry to ask, I never had to use any midi sync before.
I suggest you google "MIDI clock" and read up on it.
The ES-3 itself won't generate the MIDI signals.
Jaypee
Ahhhh fff.. I was about to buy an ES-5...then I saw
"The ES-5 is intended to be used with the latter versions of the ES-3 (Mk2, Mk3 and Mk4) as the first version has no expansions headers which means you would have to solder."
I have a MK1 version. And no soldering skillz at all.
cry
Jaypee
I ordered an USAMO... razz
Jaypee
Pfffff received my USAMO in 24h! eek!
I didn't know what to except...but I just plugged it, and it was on sync on the first try. Bim.
So easy I thought I was doing something wrong
Now I created a template in ableton using cirklon/vst/eurorack (ofc!) it's perfectly in sync!
The only pb, is when I add plug-in in ableton. It's like there is no compensation delay. Since it's not related to ES I won't comment here on it (but any help would be appreciated)
Anyway! I had an Innerclock couple of years ago. Worked perfectly with my MPC60. The Usamo is doing the same. Couldn't be more happier!
Many thanks os!
