3D-printed Arduino-powered Eurorack clock divider in 4HP
Author 3D-printed Arduino-powered Eurorack clock divider in 4HP
joeSeggiola
I made an Arduino-powered clock divider in 4HP, using a 3D-printed faceplate. The idea for a compact layout came from the 4ms RCD, but I wanted to have a different arrangement of divisions, a manual reset button for "restarting" my patches, and gate-mode option accessible from the panel. I thought it would be nice to share here.
Code and files
https://github.com/joeSeggiola/arduino-eurorack-projects/tree/master/c lock-divider
Features
- Divides incoming clock signal by 2, 3, 4, 5, 6, 8, 16, 32 (configurable in code).
- Reset as trigger or manual button.
- Down-beat counting.
- Trigger mode: duration of incoming pulses is preserved on outputs.
- Gate-mode: duration of the output pulses is 50% of divided tempo, enabled by long-pressing the manual reset button.
Pics of my build
mattip
Interesting! What is the overlay on the 3d-printed panel with text?
joeSeggiola
Thanks. It's simply a sheet of adhesive paper, printed with a standard office printer, cut and punched. I couldn't think of anything better, but the end result is not that bad, given nuts and washers will cover imperfections. Any suggestions would be greatly appreciated smile
mattip
I am having trouble printing good looking text on 3d-printed panels. Right now I print relief text and paint the text white. Does not look good. Do you use varnish over the paper?
joeSeggiola
Unfortunately the resolution of the printer I'm using is not enough to have legible text :( Otherwise, this whould be a good idea.
Varnish or adhesive film (the type normally used to cover books), I don't remember which one is in that photo. Both decent, at least you don't risk wearing out the paper.
