help with playlist text for disting mk4 multisample playback
Author help with playlist text for disting mk4 multisample playback
solipsvs
hi. im attempting to use the disting mk4 multisample playback algorithm to play lfo shapes rendered from cvtoolkit in hopes of making a rapid changeup lfo with reliable accuracy for my modular. i need help to make sure im doing it right, and am displaying my playlist.txt below. can someone who knows this chime in with pointers? i may ask some silly questions along the way.
    disting playlist v1
    -loop=1
    -gap=0
    -fadeIn=1
    -fadeOut=1
    -fixedPitch=1.0
    -retriggerOnSampleChange=0
    4.wav
    -switch=1
    2.wav
    1.wav
    12.wav
    13.wav
    14.wav
    16.wav
    18.wav
    112.wav
    116.wav
    124.wav
    132.wav
im not sure what some things will do.
what is the first line for? is that a name?
fade in/out will keep the clicks to a minimum, correct?
btw i dont want the files to play at a pitch other than the recorded.
retriggeronsamplechange does what exactly? the manual was confusing.
switch will make the first file play on midi key 0 and the rest of the list on each incremental key afterwards, correct?
i want to make sure only one sample from my kit plays at a time. it might be nice if they were crossfaded to one another, but not necessary. quick fade in/out works for me.
thanks for your help!
First line is a header just to confirm it's the right kind of file.
Setting retriggerOnSampleChange=0 means it won't start playing a sample when you change the sample selection knob/CV - it will only start playing a sample when it's triggered by a trigger input.
solipsvs
but otherwise it looks good? ok thanks!
solipsvs
by the way, those lfo samples are here
http://s000.tinyupload.com/index.php?file_id=00418003877790263990
