ES-8 wont sync to pc
Author ES-8 wont sync to pc
lostphysicist
This is fun! I just purchased a ES-8 and it is qanot showing up as an interface on my windows pc in vcvrack or ableton. I have tried different usb cables and ports, and tried both the legacy and current drivers . I pulled up the expert sleepers control panel and I can see it constantly connect and disconnect repeatedly. The usb light on the es-8 is also flashing to reflect this. Has anyone experienced this?
I attached pictures of the 2 screens it is flashing between in the expert sleepers control panel.
I would check the ES-8 is getting enough power.
lostphysicist
my power supply is .6A on +-12 and this is the only thing plugged in right now so it should be fine :(
Fair enough.
Are your USB cables definitely specified for USB 2.0? A USB 1.1 cable might cause issues.
