My new 12U live case and placement of performance modules
Live patching, designs, and techniques that push the performance envelope.
sbmani
Post by sbmani » Thu Mar 21, 2019 12:39 pm
Finally have my performance case fully setup. First gig with this new case is in a month! I like keeping the most playable / performative modules down below so I can interact with them without obstruction from patch cables. Anyone else have other configurations they like for more performative modules?
xthrasherx
Post by xthrasherx » Thu Mar 21, 2019 3:41 pm
I’m also working on a 12u performance case, my general setup from bottom to top is: sequencing and fx (the most hands on, wiggly stuff), drums and mixer (I use the wmd performance mixer), non-interactive modulation and set&forget modules, and finally hands on modulation / complex oscillators / filters. For the most part this keeps the bulk of the cables in the area I don’t need to worry about/ would be difficult to twist knobs anyway and keeps the fun stuff still easily accessible.
"While we scream and perish, History licks a finger and turns the page.”
― Thomas Ligotti
Instagram::YouTube::SoundCloud
c0rpse
Post by c0rpse » Fri Mar 22, 2019 9:49 am
I run my 12U in a side by side configuration so my performance is not obscured to the audience. An added benefit is that it gives me 208Hp of "bottom" row. It also means the cables run horizontally down the center of the system. No cables hanging over modules.
xthrasherx
Post by xthrasherx » Fri Mar 22, 2019 10:22 am
c0rpse wrote:I run my 12U in a side by side configuration so my performance is not obscured to the audience. An added benefit is that it gives me 208Hp of "bottom" row. It also means the cables run horizontally down the center of the system. No cables hanging over modules.
Are your “top” and “bottom” cases a similar depth? I’ve debated doing something similar, but my monorocket case has a shallow bottom compared to the top which makes a side by side configuration a tad annoying (flush mount on the bottom, “sunk” in on the top). I can see the advantages though.
― Thomas Ligotti
Virusinstaller
Post by Virusinstaller » Sat Apr 27, 2019 2:48 am
Looks like a good use of HP. Should be able to do plenty with that live.
minigmgoit
Post by minigmgoit » Sun Sep 08, 2019 9:43 am
I would put the stuff you need to wiggle along the top and bottom rows as you'll have easiest access to those 2 rows.
OB1
Post by OB1 » Wed Sep 11, 2019 7:54 am
minigmgoit wrote:I would put the stuff you need to wiggle along the top and bottom rows as you'll have easiest access to those 2 rows.
Yep, this. This is how I have my 12U suitcase set up. Hands on sequencers and mixers in the bottom row, filters and other things I like to tweak in the top row, stuff that doesn't need so much interaction in the middle two.
Return to “Play Out! Performance Modulars”
