Adjustable power supply load test
Author Adjustable power supply load test
Gibran
Hello everyone, what do you use for load test your power supply?
I found this one :
https://www.ebay.com/…/60W-Constant-Current-El…/262902795469
Does it work ?
Is there any steppable test like 100ma + 100ma + 100ma...?
Thank you
sduck
Better link -
https://www.ebay.com/itm/60W-Constant-Current-Electronic-Load-9-99A-30 V-Discharge-Battery-Capacity-Tester/262902795469?hash=item3d363a4ccd:g  :sBoAAOSwSLtauMiN
Altitude909
Car brake lights. There are 2 circuits there for high and low (~ 600 mA, 2. something A @ 12V) and you can run them in reverse for -12. Not a very dynamic load but does the trick and you can get them anywhere
