Rossum Panharmonium Resynthesizer
desolationjones
Post by desolationjones » Wed Mar 27, 2019 1:41 pm
"Panharmonium is a unique music and sound design tool that analyzes the spectral content of any audio signal and uses that analysis to drive a bank of from 1 to 33 oscillators. Depending on various control settings, Panharmonium can accurately reproduce the input spectrum in real time or modify it in a multitude of wildly creative ways. All with an interface whose immediacy encourages performance and interaction.
Panharmonium input can be anything from a single oscillator to an entire mix (including vocals). From dense, swirling pads and drones that evolve with the input’s changing spectrum, to clock-syncable spectral arpeggiation, to as-yet unnamed harmonic effects, Panharmonium opens up an entirely new world of sonic possibilities.
Additionally, Panharmonium can take a snapshot of an instantaneous spectrum and use that as a complex harmonic oscillator, which can then be modified and modulated by all of Panharmonium’s other controls.
Panharmonium accomplishes its magic though a combination of functional submodules:
Spectral Analyzer
The Spectral Analyzer provides tools for defining the analysis process.
  • The Slice parameter sets the rate at which the incoming audio is transformed to spectral data. It can be set by the Slice and Multiplier controls, the Tap button, or by an external clock signal. Very short slice times result in real-time spectral data, while longer times can create rhythmic spectral patterns.
    The Center Freq and Bandwidth controls (and associated CV inputs and attenuverters) control the range of frequencies to be analyzed. The Bandwidth control allows the selection of narrow to wide pass bands on the left side of the pot and narrow to wide notches on the right side of the pot. The ability to sweep the frequency and modify the bandwidth under CV control opens up a wide range of sonic effects.
    The Freeze button lets you freeze the spectral integrator, sustaining the currently analyzed spectrum.
Spectral Modifiers
These controls allow the creative modification the analyzed spectra.
  • The Voice parameter controls the number of oscillators (from 1 to 33) used to resynthesize the spectrum.
    The Blur parameter (and associated CV input) is a spectral lag processor that controls how quickly the spectrum can change.
    The Feedback control (and associated CV input) allows one to route the resynthesized audio back into the entire processing chain for subtle or dramatic feedback effects. At its max, the output becomes self-sustaining, even if the input is removed.
Oscillator Bank
The Oscillator Bank resynthesizes the analyzed spectra.
  • The Waveform parameter selects the oscillators‘ waveform. In addition to the usual sine, triangle, sawtooth and pulse waveforms, two special crossfading sine and sawtooth waveforms are included.
    The Freq control tunes the oscillators over a +/-7 semitone range. The frequency is further controlled by the 1V/Oct input and the FM input and attenuverter.
    The Octave control, not surprisingly, shifts the pitch of the output by octaves.
    The Glide parameter sets the amount of polyphonic glide (i.e., each oscillator has its own glide circuit).
    The Mix control (and associated CV input) sets the balance between the original input audio and the resynthesized audio.
Optional Functions
A number of optional functions can be selected by using the Output Mode and Tap buttons.
  • Holding the Output Mode button and adjusting the Slice control enables Drums Mode, which optimizes the spectral analysis for drums and other percussive inputs.
    Holding the Output Mode button and adjusting the Center Freq control allows one to instead set the lower frequency of the analysis range.
    Holding the Output Mode button and adjusting the Freq control enables Spectral Warping. In contrast to conventional frequency adjustment, where the harmonic relationships between the spectral elements are preserved, Spectral Warping shifts the harmonic elements individually, producing a variety of clangorous, swarming textures.
    Holding the Tap button and adjusting the Freq control quantizes the resulting frequency adjustments to semitones.
Spectra Memories and Presets
Panharmonium provides 12 user Spectra memories and 12 user Presets (in addition to 12 each factory memories).
  • The Spectra memories let you store up to 12 frozen slices. When selected, a spectrum (up to 33 oscillators wide!) replaces any live input and can have its pitch controlled by the 1V/Oct input and FM controls.
    A Preset is a snapshot of all of the module settings, along with the value of any CVs present at the moment the preset is saved.
Panharmonium is 26HP wide and 25mm deep.
Power requirements (max): 140mA +12V, 30mA -12V. Reverse polarity protected.
Panharmonium will be available in early summer from Rossum Electro-Music dealers worldwide at a suggested retail price in the US of $499.00."
spinalbeatz
Post by spinalbeatz » Wed Mar 27, 2019 1:51 pm
NEED DEMOS :eek:
mdoudoroff
Post by mdoudoroff » Wed Mar 27, 2019 1:52 pm
Cool. A super souped-up wave swarm-type thingy. In stereo.
cackland
Post by cackland » Wed Mar 27, 2019 1:55 pm
spinalbeatz wrote:NEED DEMOS :eek:
+1
Dogma
Post by Dogma » Wed Mar 27, 2019 2:04 pm
Now THAT is interesting
look up!
Ras Thavas
Post by Ras Thavas » Wed Mar 27, 2019 2:39 pm
You had me at "Mutating", Dave...
SweetNuthin
Post by SweetNuthin » Wed Mar 27, 2019 2:42 pm
WOW :banana: :nana:
pedalhead
Post by pedalhead » Wed Mar 27, 2019 2:42 pm
Dayum, I'm hoping this will be up for demo at Synthplex this weekend.
The Junglechrist
Post by The Junglechrist » Wed Mar 27, 2019 2:56 pm
Oh boy ! :bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar:
Stazma The Junglechrist / Repeat Eater: http://stazmathejunglechrist.com/
Electric Voyage Studio [Mastering / Mixing] : http://electricvoyage-studio.com
My label Concrete Collage : https://concretecollage.bandcamp.com/
Wired Brain Video Channel : https://www.youtube.com/channel/UCh4pym ... vkKp6ofzVA
koyl
Post by koyl » Wed Mar 27, 2019 3:02 pm
This could make my dream of synthesizing any external signal in real time come true.. Until now, granular synthesis was the answer but this is even better.
So yes: demos
And one question: When ?
Alexander Kuznetsov
Post by Alexander Kuznetsov » Wed Mar 27, 2019 3:11 pm
koyl wrote: And one question: When ?
June
https://www.ctrl-mod.com/products/panha ... -pre-order
LSuveg1
Post by LSuveg1 » Wed Mar 27, 2019 3:31 pm
Wow, can’t wait for a demo!
Post by lisa » Wed Mar 27, 2019 3:46 pm
Sounds very interesting based on the description but I’ve been fooled before. :roll:
I’m very much looking forward to some demonstrations of it.
New track! Drum synthesis heavy, melodic piece using Instruō harmonàig and Cš-L. 🐡
Post by exper » Wed Mar 27, 2019 3:48 pm
Good grief that’s interesting. Can’t wait to hear it.
FS/T: Goike Folding Case / Grayscale Panels
coolshirtdotjpg
Post by coolshirtdotjpg » Wed Mar 27, 2019 3:54 pm
Seems like a really souped up the version of the AD Spectre. I've always wanted a really powerful FFT module, this might be the one.
New video on Prophet 12 Drone Patches:
peripatitis
Post by peripatitis » Wed Mar 27, 2019 5:33 pm
It looks very interesting, eager to hear more details about how it does the analysis, sound examples, etc.
But i guess the main question for me is it, why not morph between the presets? And what about noise?
p.s
I wouldn't be certain though that those "as yet unnamed harmonic effects" haven't already be given a name by trevor wishart or Roger Smalley..:)
koyl
Post by koyl » Wed Mar 27, 2019 5:34 pm
June
Thanks !
That probably means we'll hear it in action soon.
Eurocat
Post by Eurocat » Wed Mar 27, 2019 5:55 pm
So this is basically a MI Clouds on steroids?
_lampshade_
Post by _lampshade_ » Wed Mar 27, 2019 6:08 pm
No, granular synthesis is different than spectral resynthesis, re synthesis i think is more akin to a vocoder or in this case I guess a bank of 33 oscillators controlled by pitch and amplitude tracking of a corresponding band of the input spectrum. any way sounds interesting.
emilng
Post by emilng » Wed Mar 27, 2019 6:43 pm
June
Thanks !
Probably at Synthplex tomorrow. Looks like Rossum is one of the exhibitors there.
mostly modular experiments: https://www.youtube.com/user/maztik8r
Funky40
Post by Funky40 » Wed Mar 27, 2019 8:08 pm
cheeesus, i read spectra and spectral even on repeat and my ears grew up in one second to the size of that rabbits ears. i look now kind of like
.......until i hear demos. Hope that will solve it
starthief
Post by starthief » Wed Mar 27, 2019 9:02 pm
Wow! There have been a couple of VST synthesizers that can do this, but I'm really eager to hear this particular take on it.
Dcramer
Post by Dcramer » Wed Mar 27, 2019 9:43 pm
Looks very interesting :woah:
Funch
Post by Funch » Wed Mar 27, 2019 9:46 pm
This looks cool. Perfect Circuit is taking pre orders.
Bob Borries
Post by Bob Borries » Wed Mar 27, 2019 10:35 pm
[√] World class transient generator
[√] World class analog filter
[√] World class digital filter
[√] World class sampler
[√] World class Oscillator
[ ] WTF that was totally unexpected
