Seaboard Block stuck notes with FH-2
Author Seaboard Block stuck notes with FH-2
JES
Greetings. This isn't really a problem with the FH-2 but I'm hoping someone is using a Roli device and reads this.
I've got the Linnstrument set up with a FH-2 and it works flawlessly. I have it set to output pitch, gate, and aftertouch to outputs 5 6 7 on the FH-2 via channel 3.
The same settings on a Roli Seaboard Block = stuck notes. What am I doing wrong? Seaboard dashboard settings are in the attached image.
TIA.
JES
Okay, it took a couple weeks to get a reply. But they told me to reset my Seaboard Block. That didn't work. But then my Roli desktop software updated itself, re-reset the block, and now it seems to work. What was that famous line about sufficiently advanced technology being indistinguishable from magic? Appears to work with bugs too.
