Cheap replacement option for Arcade Button/Microswitch pair?
Author Cheap replacement option for Arcade Button/Microswitch pair?
WonderAliceLand
I have a couple projects (one here: https://www.lookmumnocomputer.com/projects#/sequencer-keyboard) that are using arcadebutton/microswitch combos and they seem to be rather expensive.
Is there a good replacement that is cheap?
UltraViolet
If you can wait for the shipping Banggood has them for $1.93:
https://www.banggood.com/5V-Arcade-Push-Button-Durable-Long-Switch-Mul ticolor-p-957099.html?rmmds=search&ID=224&cur_warehouse=CN
All Electronics has a version for $3.75:
https://www.allelectronics.com/item/pb-216/black-jumbo-pushbutton-swit ch/1.html
WonderAliceLand
Is there not something less expensive mechanically? I mean if a simple 2 cent pushbutton would work in place somehow I would love it, but I don't know if the switches are necessary or not.
UltraViolet
The arcade style push buttons are designed to take abuse and operate for a large number of cycles. Electrically they are pretty much the same as any other push button. You could substitute a cheap push button and it would work the same, it just wouldn't look as good.
ranix
Yes. Any momentary pushbutton switch will work. The expensive arcade buttons are chosen for user interface and playability reasons. If you want to be a real cheapskate you can just touch two bare wires together and that works too
masterofstuff124
the ones on aliexpress are $1
i bought some with leds for 1.25 recently.
ive also seen 3d printed designs.
thingiverse.com
WonderAliceLand
thingiverse.com
3D printing (at least my printer) would have those buttons fall apart. I read all the comments on all the 3d printed buttons I could find and it seems they fail with 50-250 presses, yikes.
