options for more than 8 inputs
Moderators: Kent, os
JES
Post by JES » Thu Apr 18, 2019 11:52 am
Greetings. So it looks like if I hook up an ES-6 and ES-7 to an ES-8, I could have up to 12 inputs over USB -- is that correct? Would that also work over an ADAT cable, or is the max 8 channels over an ADAT cable?
Is there a way to connect multiple ES-6s to an ES-3 or ES-8 for more than this number of inputs assuming I have the ADAT inputs? I don't really need more than 8 outputs, but the ES-6 needs an ES-3 or ES-8 for clocking. I'm trying to do the mixing in software.
TIA.
"Now, I'm off to hook my cat's litterbox up to an envelope follower." --Aragorn23
Post by os » Thu Apr 18, 2019 12:04 pm
Yes.
If you're using the ES-8 without USB, you only have 4 inputs.
In theory you could daisychain multiple ES-6s off the one expansion cable, but I've never tried it.
JES
Post by JES » Thu Apr 18, 2019 5:29 pm
Thank you.
Return to “Expert Sleepers”
