Author |
Voltages and Fh-2 Calibration |
br>JES |
br>Hi Os (or anyone),
I have been having problems with auto-calibration. Both my oscillators (a Braids and a Dixie) accept voltages below 0v, so I've set the output voltages on the FH-2 to -5 to +5. But when I calibrate, it only gives me a 4-octave range. Initially I thought this might be an issue with the octave switch on the Dixie, but I'm having the same problem with the Braids.
Now here's the thing. If I DON'T calibrate, I can use the full 5 octave range of my Linnstrument (it's actually more if you transpose).
Obviously, not calibrating a digital oscillator is fine. But on the Dixie, it goes a little out of tune if I don't calibrate. Last night at practice I just used the Braids uncalibrated and it was problem free, but I'd love to find a more permanent solution. Any ideas?
Thank you. br> br> |
br>os |
br>What does the calibration look like/sound like? Are you using the cleanest output waveform on the VCO (triangle is best)? br> br> |
br>JES |
br>I’ve been using sine. Will try triangle. Basically, I lose the top or bottom octave, so if I play a note above where it’s willing to go, the FH-2 just drops it an octave. br> br> |
br>JES |
br>Reanimating this thread. I was just using the Braids and one pitch for awhile but now I really want to go back to two.
I've got the FH-2 set up this way:
1: Pitch
2: Gate
3: aftertouch
4: clock
5: pitch
6: gate
7: aftertouch
8: clock
Pitch on output 1 works fine with both analog and digital oscillators. I have saved the calibration.
Pitch on output 5 either doesn't cover enough octaves or is scaled wrong. I've tried resetting the calibration for output 5. Reset it's all out of whack -- giving me a flat 5th per octave consistently, even though in the main settings output 5 looks the same as everything else.
If I auto calibrate, I get 4 octaves of calibration, when I should be able to go 5 and a half with the Linnstrument. I've tried every output on the Atlantis -- saw, sine, pulse, sub. I have the same issue with a Braids on output 5.
Is there a way to load the calibration for output 1 to output 5? That would be the easiest solution. Or is there something else I can do in the desktop software? None of the settings there look like an obvious fix to my eyes.
This is driving me nuts.
TIA. br> br> |
br>JES |
br>Oh. My. God.
Output 5 was set to 0-5v instead of -5 to +5v. Somehow I didn't see it in the configuration. Problem magically solved. I leave this here in case anyone else has this problem. br> br> |
