FH-2 Euclidian Patterns
Moderators: Kent, os
with_joerg
Post by with_joerg » Sun Apr 28, 2019 11:45 am
Recently received my FH-2 and it is wonderful. I use it w the ROLI SB in MPE mode.
The clocks etc. work great. However, I cannot get a Euclidian pattern out of it. Maybe I misunderstand the feature. I expected it to be some sort of Euclidian sequencer / sending a number of gates in euclidian timesteps or so.
Have watched the YT film about it but did not get any smarter from it.
Has maybe someone a sample configuration with some explanation? The explanation in the manual is quite ... limited. At least for a noob.
Post by os » Mon Apr 29, 2019 1:56 am
The configuration sets up how the Euclidean is controlled - you then have to send CCs (or use the FH-2's menus) to actually activate the thing.
A minimal config looks like this:
Once you send a non-zero value to Pulses the Euclidean will start generating a pattern.
with_joerg
Post by with_joerg » Wed May 01, 2019 2:57 pm
Thanks, would there be any way to pre-configure the number of steps, the rotation etc. without the need to send Midi?
Post by os » Wed May 01, 2019 3:15 pm
You can change that by editing the preset via the FH-2's menus, and then save it as a preset.
Return to “Expert Sleepers”
