ES-8 CV Out issue
Moderators: Kent, os
druidgrif
ES-8 CV Out issue
Post by druidgrif » Mon Apr 29, 2019 4:51 pm
I just got my ES-8 and am missing something. I have VCV rack with a sequence sending steady CV changes through the ES USB Interface hitting a Rings. Instead of it triggering the rings each time the cv changes, it is triggering at audio (? or another clock rate). Is there a way to change that or am I using the ES-8 incorrectly?
What I have tried: I tried sending clock out but it just lets bursts of rings out instead of a constant stream. I have also set a LPG but it still lets bursts instead of one hit of rings per cv change.
Thanks for the help!
Post by os » Tue Apr 30, 2019 2:06 am
Can you attach the patch here? Or a screenshot at least?
druidgrif
Post by druidgrif » Tue Apr 30, 2019 2:29 pm
Here is a picture of the patch.
Brief description: Random S&H from X2 to Input 1 of the audio interface of the ES-8. Then into the V/Oct of Rings - Odd out to Input 1 of ES-8 - Audio In of ES-8 Output 1 to the recorder or speaker.
Post by os » Tue Apr 30, 2019 2:41 pm
OK. I'm not familiar with any of those modules. If you replace the ES-8 by a virtual Rings within Rack, does it behave differently?
Any reason you have another Audio module in Rack too? That might be confusing things. And they're running at different sample rates. What sample rate is Rack's engine running at?
druidgrif
Post by druidgrif » Tue Apr 30, 2019 3:03 pm
With a VCV Rack Rings, it sounds right. I'll post a file of each. The other audio interface is the Out to my speakers. I set it all to 48khz and it is the same as VCV Rack and no difference.
druidgrif
Post by druidgrif » Tue Apr 30, 2019 4:58 pm
Okay, I restarted Vcv Rack and then it started working. I think putting everything to the same sample rate and then restarting fixed the issue.
Thanks for the help, os!! Of my 5 modules so far, 2 are yours.
Post by os » Wed May 01, 2019 1:36 am
:party:
Return to “Expert Sleepers”
