Dnipro Metamorph
mdoudoroff
Dnipro Metamorph
Post by mdoudoroff » Fri May 03, 2019 9:38 am
Just took a flyer on one of these. Will report back when it arrives.
On paper, it’s a highly affordable, intriguing alternative to Pressure Points+Brains (same HP as PP alone) for those more interested in the voltage memory and sequencing than in touch plates.
For me, the killer detail is the built-in slew limiters. Dedicated per-stage gate outputs and the trigger output make it pretty complete. CV addressing a nice touch that I’ve missed having with Brains. Would’ve been nice if there was a way to set the voltage ranges other than through jumpers round back.
https://www.dnipro-modular.net/metamorph
https://www.modulargrid.net/e/dnipro-modular-metamorph
Metamorph is a versatile 4 stage x 3 channel cv source with built in sequencer and glide. Inspired by a Serge Tcherepnin concept, Metamorph is designed to control several parameters at once and creates a complex cv source for eurorack system. The main application of it is to make complex patch morphings or "preset sequencing". This transitions can fast and sharp or slow and round, thanks to build in per channel glide control. Each channel is represented by a column of pots, while each column is divided into 4 individual stages by rows, with corresponding button and gate out. It is possible to change stages manually by pressing stage buttons or to sequence them by external sources, like clock, lfo, envelopes etc. Metamorph has a special user sequence feature, which allow to program play oder and duration of the stages, create unique sequence with individual timing per stage and memorize it.
Operating Metamorph is quick and immediate in a good analog fashion, with single control per function. Two modules can be linked together to create a 8-step sequencer with dual CV outs per channel. Additionally, every channel has a deep glide control for performing fast or really slow voltage slides between stages. And, of course, there are ordinary sequencer cv inputs, like reset, hold and revers direction.
Features
3 channels x 4 step sequencer
glide per channel with wide range
two modules can be chained to create 8 stages and double outputs
selectable voltage ranges, uni or bipolar
individual gate outs per stage
cv in input for selecting stages with cv
skiff friendly
solid responsive buttons for manual stage selection
Technical details
20 hp
50 mA +12V
20A -12V
0 mA 5V
28 mm deep
output ranges: 0V to 5V, 0V to 10V, -2.5V to 2.5V, -5V to 5V
BaloErets
Post by BaloErets » Fri May 03, 2019 10:34 am
Wow! Watched the video and immediately went to purchase one. Sadly, at the moment there is no option to ship to Canada. I send an email to them hoping that there is a way to get it shipped here.
Thanks so much for that post!
Groundloop
Post by Groundloop » Fri May 03, 2019 11:30 am
BaloErets wrote:Wow! Watched the video and immediately went to purchase one. Sadly, at the moment there is no option to ship to Canada. I send an email to them hoping that there is a way to get it shipped here.
This does look interesting, and had it been available at the time I might have opted for it rather than PP + Brains.
For what it's worth, they're listed on Reverb. I was able to add it to my cart without alarms sounding, so there don't seem to be any region restrictions:
https://reverb.com/item/23085268-dnipro ... ation=true
cptnal
Post by cptnal » Fri May 03, 2019 3:42 pm
Very nice! Reasonably priced too. Being addressable is a big score over PP for me.
mdoudoroff
Post by mdoudoroff » Fri May 03, 2019 9:50 pm
Sorted out that the maker is in the Ukraine. It will be interesting to see how quickly a package gets from Kiev to NYC.
hinterlands303
Post by hinterlands303 » Sat May 04, 2019 12:05 am
Wow this looks really nice. Apparently you can link two of them as well for a 3x8 sequencer. It wouldn't replace PP and Brains for me since I use the touchplates for pressure and manual playing of the steps pretty regularly but I could see this really working for someone who just wanted to sequence and not play.
vdgno
Post by vdgno » Sat May 04, 2019 4:04 am
Hello there, glad your are interested about Metamorph. :bananaguitar:
It ships to Canada now.
Usually about a week.
Halfgeleider
Post by Halfgeleider » Sat May 04, 2019 4:39 am
Very cool module, thinking of getting 2 of these...
MATSmile
Post by MATSmile » Sat May 04, 2019 11:37 am
Ви хлопцi/дiвчата з Днiпра чи що?
vdgno
Post by vdgno » Sat May 04, 2019 12:20 pm
MATSmile wrote:Ви хлопцi/дiвчата з Днiпра чи що?
kiev) misto na dnipri
BaloErets
Post by BaloErets » Sat May 04, 2019 2:19 pm
vdgno wrote:Hello there, glad your are interested about Metamorph. :bananaguitar:
Thanks for taking care of that so quickly! Very much appreciated!
cptnal
Post by cptnal » Mon May 06, 2019 8:18 am
Just ordered myself one of these chappies. :hyper:
Dropped just at the right time for me since I was considering swapping out my PP/Brains. As hinterlands303 suggested, the touch plates are wasted real estate if you don't use them, and this guy has some nifty features that make better use of that space. (And with a 4hp saving!)
Will report back with my findings...
forrest
Post by forrest » Mon May 06, 2019 7:45 pm
This thing looks awesome, I definitely want to pick one up.. I like the possibility of 12 steps using a seq switch and the sequencing sounds pretty cool..
Question: the user guide says the record mode patterns can be "really long" .. I guess there is no real limit to that? Also, does it record gates or is it recording triggers? That is, will it record long presses? I see it can do rests which is nice..
mdoudoroff
Post by mdoudoroff » Mon May 06, 2019 7:56 pm
forrest wrote: Question: the user guide says the record mode patterns can be "really long" .. I guess there is no real limit to that? Also, does it record gates or is it recording triggers? That is, will it record long presses? I see it can do rests which is nice..
It appears to me the user pattern mode simply records your presses of the stage buttons, and then during playback, each clock trigger advances through that sequence.
forrest
Post by forrest » Mon May 06, 2019 8:00 pm
Well it says in the documentation : "which allow to program play oder and duration of the stages"
Which btw, couple spelling errors in the manual, no big deal ;)
If it does record gates that would add a lot of playability..
vdgno
Post by vdgno » Tue May 07, 2019 2:26 am
There is a limit, 500 button presses per sequence.
It doesn't record gates. The trigger output fires only when a stage is changing. When you pressed f.e. a stage button 4 times during programming user sequence - metamorph will playback that stage 4 clock pulses long and supply one trigger.[/quote]
cptnal
Post by cptnal » Wed May 08, 2019 2:39 pm
Hey there, early adopters (or manufacturers, if you're listening). In lieu of actually getting the thing in front of me (soon!), I'd be interested if anyone can provide an insight as to how slow the slew can get. :hmm:
TIA
vdgno
Post by vdgno » Fri May 10, 2019 7:23 am
https://www.youtube.com/embed/qRphKMgtuvI
cptnal
Post by cptnal » Fri May 10, 2019 12:22 pm
:tu:
Thank you.
cg_funk
Post by cg_funk » Fri May 10, 2019 12:30 pm
Nice, the adjustable glide per step is one of the features of the Tetrapad that I really love and use. I think they implemented it on the panel is like the best possible way too.
I like the interface design of this! They basically turned PP+Brains on its side to make it less wide and gave it really nice looking buttons instead of those flunky contact pads. CV control over the stage is pretty sweet too.
mdoudoroff
Post by mdoudoroff » Sat May 11, 2019 3:30 pm
Mine has arrived in perfect condition. Took seven days to reach us port of entry, two days to get delivered to me in Manhattan. I’ve plugged it in and run a bunch of basic tests and everything is as expected. Build quality seems nice.
Will try to put together a sample clip tomorrow.
atrostor
Post by atrostor » Sat May 11, 2019 8:30 pm
Looks great. Looking forward to your opinions. I am also curious about the mesh surface underneath the module in that picture :eek:
mdoudoroff
Post by mdoudoroff » Sun May 12, 2019 8:20 pm
atrostor wrote:Looks great. Looking forward to your opinions. I am also curious about the mesh surface underneath the module in that picture :eek:
I have the Metamorph going in a patch, today. It’s not a great patch, but I’m making extensive use of the Metamorph, including the slews. It just works. Knobs and buttons all feel good. Kinda wish it was 4-5 channels instead of 3.
I’m actually using one of the channels to control an ADDAC306, which gives me five more animated CVs to alter my patch with. The other 2 outs go to my Performance Mixer to alter the mix—my main application for the Metamorph is defining distinct “song sections”.
I’m running one of the gate outputs to a logic module. (If you’re wondering, the gate outputs seem to produce 4.3v.)
I’ve left all three channels at the default 0-6v setting, and I expect that won’t change for my purposes.
Haven’t used SEQ feature yet, except to verify it works. It does. Very straightforward.
Great value, this module.
cptnal
Post by cptnal » Mon May 13, 2019 2:48 am
Nice work! :tu:
That's kinda the context I imagine using it in. You could even contrive entire structures by addressing it with a sequencer... :eek:
According to the tracking mine left Ukraine on Friday. :hyper:
cptnal
Post by cptnal » Tue May 14, 2019 2:58 pm
cptnal wrote:Nice work! :tu:
Got it today. Actually arrived yesterday when I was at work, so six days door to door. Not bad!
First impressions - I can see this being my go-to automated variety machine. The module itself, the gate outs that can be tripping sequential switches or whatever... The trigger out in addition to the per-stage gates is a nice touch, especially in CV-address mode (where it doesn't just act as a clock-through).
TL;DR - Happy customer. :party:
And those knobs aren't going anywhere by accident. Wish I had one on Shapeshifter's coarse tune. :ripbanana:
