Serge won't calibrate
Moderators: Kent, os
Nisse_D
Post by Nisse_D » Fri May 03, 2019 8:17 pm
Hi, can't find a similar thread although i'm sure it's been asked before; how on earth do you get a serge to calibrate? When i use the calibration curve from my MS10 it plays along nicely (altough all out of tune of course) but as soon as i start a volt/octave calibration i can hear the scaling begin, but no curve is drawn and when the sequence is done, no more cv output. Do i need to do any special setting? Im running my THC 73-75 homebuilt system straight into my MOTU ultralite MK3 with a sine wave just going trough the VCA, i've also soldered the appropriate 1/4 to banana with floating ring, ground to ground jack etc. Any ideas would be much appreciated!
Post by os » Tue May 07, 2019 2:27 am
If the Voice Controller's calibration curve isn't updating during calibration, that would indicate that the plug-in isn't getting an audio signal from the VCO.
Return to “Expert Sleepers”
