Hertz Donut mk III FIRMWARE ver 1.51 released
MUFF WIGGLER Forum Index -> The Harvestman
Author Hertz Donut mk III FIRMWARE ver 1.51 released
mt3
https://ime-assets.s3.amazonaws.com/uploads/firmware/firmware/35/donut mk3v151.zip
v1.51
May 23, 2019
Bug fixes:
* fixing a bug on the modulation operator's upper frequency limit
v1.5
May 20, 2019
Bug fixes:
* Deglitched phase distortion knob and CV input.
* Removed noise from the entrance of the resonance parameter.
* Eliminated leading zeroes from frequency display.
New features:
* Extended frequency resolution. Fine tune is finer, attenuated modulation is more subtle.
* New shortcut: hold OP B SELECT and turn encoder to change octave of main oscillator (like Piston Honda)
* Wider range coarse control in operator Free mode.
v1.2 May 2, 2019
Bug fixes:
* Pitch attenuators now properly stored/recalled in preset.
* Operator tracking and link settings now properly recalled from preset.
New features:
* Operator Follow mode now allows you to set frequencies below that of the main oscillator.
* Increased sampling rate on CV inputs for better transient response on fast-moving signals.
v1.1 March 1, 2019
Bug fixes:
* Rotary encoder behaves better.
* Various bug fixes regarding operator A/B quantize/link storage in presets. If your presets use anything other than the default values of these menu items, we recommend you initialize and recreate those presets.
* Slider LEDs will now update correctly when switching operator focus.
mt3
FIRMWARE ver 1.5 released.
Updated original post.
mt3
FIRMWARE ver 1.51 released.
euxine
I a PicKit 2 no longer usable for updating?
mt3
It should be fine.
The question most people are asking is "which PicKit should I buy?", which it's recommended to buy PicKit 3 since it does what PicKit 2 does (and much more).
