Wiring of the assign switch on the PolyDAC
terjewinther
Post by terjewinther » Sat May 04, 2019 5:02 am
I have the old 4-channel MIDI-CV module, the PolyDAC. It has a switch for "assign" of the 4 extra CV outs.
How is it supposed to be wired? I think it is marked J1 in the schematics.
Is it to momentary link to ground when used, or should it be disabled from ground when used?
Schlumpfhut
Post by Schlumpfhut » Sat May 04, 2019 12:26 pm
On Elby - which sells the PolyDAC also - a wiring diagram can be found which covers everything
http://www.elby-designs.com/webtek/poly ... wiring.pdf
Synthbuilder
Re: Wiring of the assign switch on the PolyDAC
Post by Synthbuilder » Sat May 04, 2019 2:20 pm
terjewinther wrote:Is it to momentary link to ground when used, or should it be disabled from ground when used?
It's a simple momentary switch that shorts the two pins of J1 together when pushed. One of the pins on J1 is 0V and the other pin connects to the microcontroller.
I would use a twisted pair of wires to connect J1 to the switch and don't make the wires too long.
Tony
terjewinther
Post by terjewinther » Sun May 05, 2019 1:52 pm
Thanks for the replies - very useful. Will wire up and test.
