ModyPoly clock selection
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
sgariplerden
Polysix 61midi clock sync question
Post by sgariplerden » Sun May 05, 2019 2:31 pm
Hi,
I would like that my polysix internal arp follows the midi clock signal from an external controller. On your video on youtube, you active the external midi clock by pressing the key D5 just after the G from the logo KORG polysix on the right part of the polysix which according to the user manual, corresponds to the SH-LFO m. clock.
So to achieve what I want to achieve, I have clicked on HOLD, then followed by G4, arp midi clock. But then when I quit hold with an incoming midi clock signal, I press keys but no notes are being played and arpeggiated. I am sure that I am missing something. I welcome any help ! Best, Samuel
tubbutec
Post by tubbutec » Mon May 06, 2019 6:34 am
[The video was created with an early firmware version which had a slightly different config menu.
Make sure you are not sending any midi to your Polysix while in the config menu
  • Press HOLD until it starts blinking
  • Press G4 (midi clock)
  • Press HOLD again
  • Make sure your Midi host is actually sending a midi clock
  • START/STOP may be required
sgariplerden
Post by sgariplerden » Fri May 10, 2019 5:27 am
Ok, perfect, it works. Thank you !
Return to “Tubbutec”
