Juno-66 power arp not triggering in mono mode
MUFF WIGGLER Forum Index -> Tubbutec
Author Juno-66 power arp not triggering in mono mode
namesshmames
I've ran into an issue in which the power arp works correctly in other modes, but in mono mode it only works on the first press, not the second and then will work on the third and so on. So it will skip each next key press. If you hold the key from the first press or use the hold function it works and transposes the sequence correctly, but if you retrigger the arp it then it wont sound on the next key press.
