ES-8 / Ableton / VCVRack / SilentWay issues
Author ES-8 / Ableton / VCVRack / SilentWay issues
boombipbass
Hi,
I want touse the programs mentioned in the topics but I have my own soundcard. Its annoying to only use ES-8 via USB so then I have to wire my speakers to my modular too and have no control.
How could I just put the ES-8 on my Orion32+ soundcard/audiodriver alks still use VCVRack and SilentWay instead of only sending and receiving audio?
How do I adjust the settings withsilentWay or VCV Rack with ES-8?:-(
flipper16
Connect the ES8 to the Orion32 using the ADAT ports.
ciso
Use aggregate devices: https://help.ableton.com/hc/en-us/articles/209071609-Using-Aggregate-D evices-and-multiple-audio-interfaces
boombipbass
I did but I can only send/receive audio :(
boombipbass
I have windows :(
flipper16
Maybe you should ask this in the Expert Sleepers sub-forum!!!
https://www.muffwiggler.com/forum/viewforum.php?f=35
You'll probably get an answer from os himself... thumbs up
ciso
boombipbass wrote:
I have windows :(
From the link:
Aggregate devices on Windows
On Windows it's not possible to create aggregate devices at a system level.If using the MME/DirectX, you can select two different devices for input and output (like on Mac). If using the ASIO driver, it's only possible to select one device as both input and output in Live's preferences.
It is possible however to combine interfaces using ASIO4ALL. Check this third party video tutorial for instructions.
Otherwise if your interface has Multi-device support, check the section below.
evileye0702
What's preventing you from sending CV via ADAT channels?
Aggregate devices are a bit of a pain in Windows but ASIO4ALL is your only alternative if you can't use that ADAT.
