[SOLVED] FH-1 Firmware Update Problem
Moderators: Kent, os
smutek
Post by smutek » Sun May 12, 2019 7:04 pm
Solved by using a larger capacity drive. The thumb drive I had been trying to use was only 16GB. I'm back in action! :sb:
Hi,
I'm trying to update my FH-1 to the latest firmware, 2.2. I've formatted a USB to FAT 32 and have copied image.hex to the USB thumb drive.
I inserted the USB drive into the FH-1 and powered on my skiff. When powering on, the FH-1's blue and red lights alternated as the manual indicated they would.
Next, when pressing and holding the encoder for one second the light display flickers briefly (less than a second) as if it's begun to load the firmware, then stops immediately after with lights B, F and 1-8 are all lit, solid. The unit is stuck like this.
After about 10 minutes I powered my skiff down, removed the thumb drive and powered the skiff back on. Now lights H and 8 are alternating indicating there is no firmware loaded.
I've tried re-formatting and re-loading the firmware but the unit gets stuck again, as previously described.
Any help would be greatly appreciated. I bought this unit used a few months back and have had zero issues with it till now.
Thanks in advance for any insight.
Return to “Expert Sleepers”
