Elby Tube VCA calibration questions
Author Elby Tube VCA calibration questions
devinw1
Hey, ya'll! I just built one of these and seems to work fine, but I'm not quite getting the calibration to work out. The guide says to feed in a 2Vpp 200Hz triangle and set the multi-tun trimmer until the signal goes away, and then another 1/2 turn back. Then turn the single turn trimmer to get an ouput of 5 Vpp. My problem is that I have to rail the single turn put all the way to CCW and get only about a 4.1 Vpp signal. I can get a bit more by adjusting the multi-tun pot, but then the bleed-through that is adjusted out in step one will come back.
Also, I've noticed the output has a fairly distinct 60 cycle hum coming through that is louder than I would expect.
Anybody else have any experience with tone of these and have any words of wisdom?
nimmen
60hz sounds like mains/power hum, but you should probably hear it from other modules also.
https://en.wikipedia.org/wiki/Mains_hum
devinw1
Yes, I beleive it is mains hum. I just tend to call it 60 cycle hum. I'm using the Rack Brute case and don't hear anything particularly obnoxious on other modules. It's just this one.
