19" Rack Ears for 1U Eurorack
Author 19" Rack Ears for 1U Eurorack
peterpanderretter
Hello,
I am searching for 19" Rack Ears (such as Tip Top Z ears) which are compatible (mountable) with the common Eurorack profiles (Zrails, doepfer rails , ...) in 1U height?
Any thoughts?
thanks for helping
Peter Pan
Synthrotek has some:
Please note: Synthrotek's Eurorack Brackets only work with Synthrotek and Vector rails. Other manufacturers' rails will not work. Intellijel and Vermona modules will not fit as they are a slightly different format.
https://store.synthrotek.com/1U-Eurorack-Bracket-Ears_p_351.html
peterpanderretter
Yes! (Thx)
Is there any alternative product in black?
peterpanderretter wrote:
Yes! (Thx)
Not from Synthrotek that I know of. I'm pretty sure I've seen 1U ears from another manufacturer but I can't remember at the moment who it was.
If you have the ability and tools to drill holes in metal accurately you could try using 1U rack ears intended for other equipment, there are quite a few out there for computer equipment and some audio gear as well. It could be a waste of money trying though because the existing holes probably wont line up correct for modular rails and the existing holes might make it difficult to put nice holes where you need them if they overlap etc. Here's an example below, just do a Google search for similar items:
https://www.kvm-switches-online.com/ibb-bracket.html
