Malekko Voltage block Clocking Issue
Author Malekko Voltage block Clocking Issue
xrd1
Hi everyone, I have a problem with the voltage block.
I'm trying to make the steps run correctly through a yarns module, the steps don't turn smoothly, every so often some of them get stuck. I tried to shorten the gate length of the steps without any satisfactory results. I also did a test with a wmd mini slew using the end of cycle I get hiccups output.
Even by changing the jumper setting things get better.
kat
lots of ppl have had issues with malekko products like voltage block and the varigate 8+. have you tried using the search function? probably a lot of discussion on this. hope that helps!
xrd1
Ok thanks
