Silent Way Support For 0 to +8v Scale Like On MS-10/20/50
Moderators: Kent, os
joe boots
Post by joe boots » Tue Sep 14, 2010 1:19 pm
I use the MOTU 828mkII and Korg MS-10/20/50. does Expert Sleepers Silent Way pass calibration and support 0 to +8v scale on the Korg MS-10/20/50 or does the Korg MS-10/20/50 need additional bias voltage? could I use the ES-2 module to generate additional bias voltage with my MOTU 828mkII or another audio interface?
I was considering using MOTU Volta until I read the info below about MOTU Volta calibration.
MOTU Volta states that "Korg MS-10/20/50 - While Volta supports Hz/v scaling, the Korg MS-10/20/50 will not pass calibration without a additional bias voltage. This issue, plus the fact that these Korg models wish to see a 0 to +8v range means these monosynths are not supported at this time. It is reported the Korg MS-10 will calibrate using the FREQ input, however."
"MOTU Volta Calibration"
http://www.motu.com/products/software/volta/calib.html
Post by os » Tue Sep 14, 2010 1:25 pm
See this thread:
viewtopic.php?t=8604
joe boots
Post by joe boots » Tue Sep 14, 2010 1:29 pm
os wrote:See this thread:
thanks. I'll take a look at the thread.
ringstone
antipodean experimentalist
Post by ringstone » Tue Sep 14, 2010 9:54 pm
It shouldn't need a bias voltage, you should restrict the output of your voice controller so it only outputs +ve control voltages (as Os pointed out in this thread: viewtopic.php?t=20365). My MS-20 works fine like that from my 828 Mk I (of course I don't get the full range as it won't output up to 8V). You would need something like the ES-1 :hihi: to get that as then you could scale the 828 Mk II output to the full 0-8V range.
Also, you will get more range using the VCO freq input as it's V/Oct.
Return to “Expert Sleepers”
