Inline Attenuators of Pugix
home of post-70s electronics
Moderators: Kent, bartlebooth
hemeroscopium
Post by hemeroscopium » Thu May 16, 2019 4:23 am
Hey guys, anybody knows which part should i use now to replace the 1090NS mentioned http://pugix.com/synth/inline-attenuators/ by pugix? Would love to make a small box of these...
ClausF
Post by ClausF » Thu May 16, 2019 5:01 am
Pugix says: So here I have used a 1M audio taper pot as a series resistor.
So an 1M log pot will do the job. Anyway, it's for CV so I would use a 1M lin pot.
hemeroscopium
Post by hemeroscopium » Thu May 16, 2019 8:56 am
rmro
Post by rmro » Wed May 22, 2019 11:30 am
I'm going to build some of these too.
Are these what I need in terms of banana jacks https://uk.farnell.com/johnson-cinch-co ... dp/2340491
And for pots:
https://www.thonk.co.uk/shop/alpha-9mm-pots/ 'VERTICAL: A1M - 1M Audio'
Can't source any kind of enclosure yet, if there's anything out there?
pugix
Post by pugix » Wed May 22, 2019 12:49 pm
rmro wrote:I'm going to build some of these too.
Those will work.
rmro wrote:And for pots:
Those vertical pots are meant to solder into PC boards. You can still use them, but harder to solder to than ones with lugs.
rmro wrote:Can't source any kind of enclosure yet, if there's anything out there?
Almost any small box will do. Deep enough for the banana jacks.
Richard
https://www.pugix.com
hemeroscopium
Post by hemeroscopium » Thu May 23, 2019 3:54 am
Maybe someone can help me and make also a mute button? I'll 3d print cases for 10 of this.
rmro
Post by rmro » Thu May 23, 2019 6:32 am
Re Alpha Pots...Ah of course.
So these should work ok?
https://uk.farnell.com/bourns/pdb181-e4 ... dp/1823527
nrrrd
Post by nrrrd » Thu May 23, 2019 6:44 am
@rmro, if you're in the UK then bitsbox.co.uk and soundtronics.co.uk are a good source for pots and other components.
Bitsbox:
https://www.bitsbox.co.uk/index.php?mai ... ts_id=3190
Soundtronics:
https://www.soundtronics.co.uk/taiwan-a ... m-log.html
(both 1M log response)
I like Bitsbox as they have everything you need, but only one of them, so it takes the problem of choosing which variety of an IC out of the equation, they deliver quickly and it's an independent small business. You just have to factor in the £1.75 flat shipping fee for everything you buy.
rmro
Post by rmro » Thu May 23, 2019 11:25 am
Hey thanks, yes I am in the UK.
I just completed a Meng Qi Rollz build and used Bitsbox a lot for capacitors and other things I ordered wrongly or forgot :bang: certainly felt less intimidating than the Mousers style sites.
rmro
Post by rmro » Thu May 23, 2019 11:28 am
I'm thinking it could be cool to mount a few on a strip, looking a bit like a format jumbler with the pots down the middle. Maybe do a quick test first
T. Jervell
Post by T. Jervell » Wed Jun 05, 2019 1:50 pm
Sooo I made a quick and dirty version of this. Doesn’t look good, but it works like a charm! Thank you to everyone who contributed to this thread :yay:
Doublecoolbossman
Post by Doublecoolbossman » Wed Jun 05, 2019 3:18 pm
Cool box! :deadbanana:
rmro
Post by rmro » Wed Sep 11, 2019 5:15 am
Finally getting round to building one of these.
If I remember I will need to solder a bit of wire to bridge two of the three lugs on the pots, is this correct?
thanks
BergotMusic
Post by BergotMusic » Wed Oct 23, 2019 9:15 am
While taking some glamour shots for an upcoming tape release I decided to grab some shots of my attenuating box to share with everyone here:
Got the walnut from a buddy of mine and cut the box on the cnc I use at work. I used some husky 14awg just in case my other, more slender options would have caused resistance when sending signal through tiny wire. Very happy with how this came out and it's so useful with my PB. Have yet to try it with tetrax and will make a lid for the bottom eventually.[/img]
ookrsia
Post by ookrsia » Thu Oct 24, 2019 9:21 am
BergotMusic wrote:While taking some glamour shots for an upcoming tape release I decided to grab some shots of my attenuating box to share with everyone here
It's a beauty!
Return to “Ciat-Lonbarde”
