es-3 low signal out
Moderators: Kent, os
nhouse
es-3 low signal out
Post by nhouse » Tue May 21, 2019 5:41 am
I'm still trying to figure out how i can use at best the es-3 to trigger events on the system . When i send triggers from voice controller , the signal coming out from the module is low such that it doesn't trigger the make noise rené. I must pass it through other modules to make it sharp and high enough to work. Is that mormal?
cheers
Post by os » Tue May 21, 2019 5:43 am
No. The ES-3 can output 10V which is more than enough.
Have you faded the plug-in output e.g. on a DAW track fader, or your audio interface's mixer?
nhouse
Post by nhouse » Tue May 21, 2019 11:51 am
yes got it was faded. i must pay attention to that detail. thanks a lot. amazing product indeed!
Return to “Expert Sleepers”
