Bitwig Grid — Cosine Window module
Post your patches here! Put the format(s) in the subject.
j_dowe
Post by j_dowe » Tue May 28, 2019 12:02 pm
I can hear what the Cosine Window module does (it seems to provide some smoothing after the Wavefolder), but I don't really understand why it works.
Any insights?
The Space Disco
Post by The Space Disco » Thu Jun 20, 2019 3:25 pm
Haven’t tried it yet. What does it says in the help menu?
j_dowe
Post by j_dowe » Thu Jun 20, 2019 3:51 pm
The Space Disco wrote:Haven’t tried it yet. What does it says in the help menu?
it's not very detailed. here it is:
btw, the Formanatee preset uses it.
pekbro
Re: Bitwig Grid — Cosine Window module
Post by pekbro » Tue Jul 21, 2020 8:10 pm
A window function is just that, it returns a zero outside of some interval, in this case the interval formed by a cosine function on the source.
When you multiply a signal against it, that signal will return zero outside that interval, this leave only the area where they overlap.
E.g. the window. So, something like a gate, derived from the multiplication of 2 signals, rather than an explicitly defined gate very probably.
Arneb
Post by Arneb » Wed Jul 22, 2020 12:23 am
Any insights?
Looks like the concept of "window functions" in DSP. Now indeed the documentation screenshot you posted is pretty lousy; they should at least have told you whether they apply that cosine-shaped window function in the time domain or in the frequency domain. In the former case, I'd expect it to act as something like an ASR envelope; in the latter case, something like a band pass filter.
Return to “Synthesis Techniques”
