Cverse
Author Cverse
zoukouard
CVerse
https://gumroad.com/l/CVerse
Package of 16 midi, instruments and effects devices to shape control voltages from Ableton Live 10 and send them via your DC coupled digital to analog converters (Expert Sleepers, MOTU, Universal Audio, Presonus, Lynx...).
Parameters are automatically mapped to Ableton Push and "Push-like" encoder/display controllers.
- Audio out (audio effect device)
Routes the signal to up to 24 simultaneous outputs (auto-detect available outputs), mute, level (bi-polar) and naming for each of the output. Each instance of this device is sharing with the other its configuration. Save and recall user default parameters.
- Audio in (audio effect device)
Route an external audio source to the chain, embedded oscilloscope to monitor the incoming signal.
- MIDI poly (midi effect device)
Split polyphonic MIDI sequences to 2 to 5 monophonic ones and route them to the MIDI mono devices in voice mode. Detect and displays the last recognised chord name.
- MIDI mono
Convert MIDI polyphonic sequences to monophonic ones (monophonic mode) Receives one voice of a polyphonic sequence sent from the MIDI poly device.
- Calibrate
Create a calibration curve preset tailored for each of your oscillators. Save them for later use with the Pitch and Quantize devices.
- Pitch
Convert MIDI note and pitch bend messages to pitch CV signal. The conversion is made using the calibration presets files created with the Calibrate device.
- Quantize
Receives signal from the chain or a MIDI automation and convert it into pitch signal allowed by the chosen scale. The conversion is made using the calibration presets files created with the Calibrate device. Control over the overall output octave range.
- Gate
Convert MIDI note-on/off to gate or trig signal. Level can be modulated by the velocity. In Trig mode control over the pulse width of the signal. MIDI note fIlter allowing only 1 or all except 1 note to be converted. Embedded oscilloscope to monitor the signal.
- Envelope
Generates AD or ADSR envelope when triggered by MIDI note-on messages. Control over length and shape for the A D R stages and over level for the sustain. Velocity can modulates the general level. Re-trigger mode. Loop mode (AD envelope only). Output level section*. Embedded oscilloscope to monitor the signal.
- Expression
Convert the selected MIDI modulation sources to a signal. Output level section*. Embedded oscilloscope to monitor the signal.
- Function
Generates functions. In the sync loop mode the function will loop on itself, the size of the loop will depend on its length. In the note trig mode MIDI note-on messages received from the inlet of the device will trigger the function. Loop & note mode combines both of the triggering methods. MIDI note fIlter allowing only 1 or all except 1 note to trigger the function (note trig and combined modes only). General level can be modulated by the incoming velocity value. Output level section*. Embedded oscilloscope to monitor the signal.
- LFO
Generate a low frequency oscillating signal. Seven shapes. Bitrate. Rate in bars or in hertz. Offset. Output level section*. Embedded oscilloscope to monitor the signal.
- Step
CV Step sequencer with 2 transport modes: Sync (locked to Live's transport bar) and Note in (next step is triggered by MIDI note-on messages received by the chain of the device). MIDI note fIlter allowing only 1 or all except 1 note to trigger the next step (Note in mode only). Control of the rate in bar division (sync mode only). Swing level. Playing direction. Up to 32 steps loop. Resolution from 2 to 120 discrete values (Y axe). Randomisation of the looped steps. Output level section*. Embedded oscilloscope to monitor the signal.
- Map
Convert MIDI values to a signal. Great for mapping an envelope follower, a modulation source, or a MIDI automation. Output level section*. Embedded oscilloscope to monitor the signal.
- Clock
Generates 2 signals. One clock signal from 1 pulse per bar up to 24 pulses per quarter note (PPQN). One start/stop (gate) or reset (trig) signal with pulse width and level controls. Embedded oscilloscope to monitor the signal.
- Oscilloscope
Monitor incoming signal. Control over zoom and speed. Level monitor in herz, MIDI note, note number or value.
*Output level section: mute, invert, smooth, jitter, level (bi-polar), follow Live's transport bar status ( F ), oscilloscope visibility ( ∿ ).
