Tascam Portastudio 414 PitchHack
Author Tascam Portastudio 414 PitchHack
LEPOINT
Hi,
I feel a little bit disappointed by the fact to be unable to go more than 3 semitones up or down with the big pitch control on the top right of the tascam.
Does someone tried to hack the pitch in order to go furthermore?
Like this (very talented) guy AMULETS :
https://www.instagram.com/p/Bx2eCJqhlJ0/?utm_source=ig_web_button_shar e_sheet
THx
Nico
LEPOINT
i might also show a picture of the Tascam Portastudio 414 i was talking about ...
https://enmoreaudio.com/wp-content/uploads/2017/09/Tascam414.jpg
selfdestroyer
The easiest option would be to just swap out the pitch pot with a different value. I would just grab a few different values and test to taste.
I did this little cheap tape recorder a few years back:
http://music.codydeschenes.com/?p=3126
LEPOINT
Thx, that is the kind of simple solution i like !
wackelpeter
haven't seen the schematics but in many cases there is a fixed resistor in series with that pitch pot, determining the Minimum resistance and fastest Speed... reducing that one too and having a bigger value pot for the pitch Control should give you ´more range on both sides (faster/slower)…
obviously the "Standard" Speed wouldn't be anymore in the middle Position of the pitch knob, and must be dialed in manually if you like to playback a normal audio tape...
