FH-2 CC feedback to midi devices
Moderators: Kent, os
javes777
Post by javes777 » Fri Jun 07, 2019 7:58 am
Hi Os,
Does the FH-2 transmit midi CC back to the devices they are sent from? Just asking because, even though you can save presets, when I power down my midi controller (Beatstep and Beatstep Pro), all values reset to 0, which will then change the presets the next time I try to use them (one at a time as I turn the knobs). So unless I keep a written record of everything and reach those values again, I'd loose the progress I've made.
Unless I'm missing something? .. which is entirely possible. :)
I've tried to set the Beatstep to relative CC mode, but that doesn't work..
javes777
Post by javes777 » Wed Jun 12, 2019 6:02 am
Bump. :)
Be interested to hear how others manager this?
Post by os » Wed Jun 12, 2019 10:03 am
The FH-2 doesn't send back the CCs currently, no.
javes777
Post by javes777 » Wed Jun 12, 2019 1:13 pm
Could a simple solution be to show on the display the cc of the saved preset for the cc you are changing?
Or maybe there could be a setting to not change the cc until the preset value has been reached on the controller, like a lot of synths with presets have.
Return to “Expert Sleepers”
