Antumbra Rot8 build failure
Author Antumbra Rot8 build failure
forrest
So I've spent the last 8 hours soldering up an Antumbra Rot8, and I think I might have to chalk this one up to a learning experience very frustrating cry
When I first was trying to program using my AVR programmer (avrdudess/utiny programmer from sparkfun) I'm pretty sure I plugged the cable in upside down on the Rot8 and was sending it power (5v) in that flipped position, could I have burned something out?
While flashing, e-fuse would not let me set it to 0x05, it required that I set it to 0xFD, the other fuses set fine to l-fuse 0xFF and h-fuse 0xDE. I read on a few forums 0xFD would be fine as it's the new 0x05 (https://forum.arduino.cc/index.php?topic=577711.0)
The flashing went fine after that, I plugged it in, reset the module, got the startup animation. It seems like all the interface stuff works, leds/buttons all react as they should. The gate out gives me a solid gate that I can adjust the length of via the internal configuration, the CV out seems to play the first 4 places, only the first LED will go green, the 7th goes orange when it hits, the others don't change during the play cycle but the first 4 pots do modify the signal in those cases. The other pots don't seem to do anything to the signal.
5v jumper configured on back.
Startup : https://youtu.be/0FXbun6aZ6I
Sending clock : https://youtu.be/zotpWQSXv6Y
Close up photos of my soldering / the board : https://drive.google.com/file/d/1T02Ml535WHr43sHpJGwH7mBToXKsTBGG/view  ?usp=sharing
If anyone has any ideas I would be happy to hear them!
Dead Banana
