Diy clock module
Author Diy clock module
msegarra
I use pamelas workout as my main clock in my main rack but I’m building a secondary synth and wanted to make a good clock module if there is one in existence anyone have any suggestions for one?
euromorcego
maybe check here: https://www.muffwiggler.com/forum/viewtopic.php?t=218331
The recent StartUp module from music thing modular has a clock. Shakmats lcok o+ pawn is available as a diy kit. Rebel Technology also has a simple clock module which is open source: https://www.rebeltech.org/product/clk/ There were also some other threads about a diy poor version of Pamela.
Of course, you can take any square lfo as a 'clock'.
And there is Barton: http://www.bartonmusicalcircuits.com/vcclock/
The pcb can also be wired much simpler, just a clock with some divisions.
Also 'temps utile'. Maybe not super intuitive to use as a simple clock? But easier to build than O_C I think because one of the more nastly smd components is missing.
Eric the Red
https://www.haraldswerk.de/Gate_and_Trigger/BPM_Generator/BPM_Generato r.html
There’s this from Harald.
keninverse
Temps Utile. If you need something really simple then nothing is more simple than a 555 timer or even an op-amp wired up as an oscillator.
woodster
Shakmat does a kit of their Clock o Pawn module.
electricanada
http://www.tindie.com/products/pmfoundations/clock-generator-eurorack- pcb-set/
