Random Source Serge VCFS Build issue 4u TH
Author Random Source Serge VCFS Build issue 4u TH
jersupereq
I just put together the 4u thru hole version of the serge filter 4x4. The VCFQ works perfectly but the VCFS(V1.02) has 2 chips, ic3 and p1, that overheat when plugged in.The rails are not shorted and I can't find any other shorts on the board. Some of the continuity seems odd but I can't tell if its normal without removing a ton of parts. A schematic would make debugging much easier, does anyone have one?
