Boredbrain INTRFX Eurorack FX Interface
soundshaper
Post by soundshaper » Mon Jun 17, 2019 9:20 am
Hey wigglers, an official announcement here....
We've just introduced INTRFX, a small external effects interface for eurorack, pedals, line-level synths and instruments, etc. It is available now! Thanks for checking it out, and please let me know if you have any questions. Intro video coming soon.
-Adam
https://www.boredbrainmusic.com/product/intrfx/
Boredbrain INTRFX
The INTRFX facilitates effects processing between eurorack, guitar pedals and electronic instruments.
  • 3 channels of send & return level conversion
  • Per-channel selection of either eurorack thru pedals or line-instrument thru eurorack
  • FX blend control with CV input
  • Capable of FX feedback and linear VCA functionality
  • Small tabletop form-factor
The INTRFX allows eurorack-level signals to be processed with pedals and/or outboard effects, and also allows line-level instruments to be processed with eurorack modules. Each of its three channels has an Interchange Switch to swap this mode, as well as an FX Blend parameter which can be controlled via CV. Because of its compact physical design, the INTRFX can be placed almost anywhere and connected to eurorack systems with 3.5mm patch cables rather than bulkier 1/4-in cables.
Feedback effects can be achieved by switching into the "wrong" mode, sending the FX return back into the FX send, while still allowing for dry signal blend and modulation. Channels can also be patched into one another and toggled between modes for experimental routing. Conveniently, each channel can operate as a reversed linear VCA for both audio and DC signals when no effects are used.
paperCUT
Post by paperCUT » Tue Jun 18, 2019 3:15 am
Thats a really cool device. How is it powered?
naos
Post by naos » Tue Jun 18, 2019 7:13 am
paperCUT wrote:Thats a really cool device. How is it powered?
soundshaper
Post by soundshaper » Tue Jun 18, 2019 10:12 am
Boss standard 9VDC negative center 2.1mm (75mA).
BenA718
Post by BenA718 » Tue Jun 18, 2019 10:31 am
Crap; I literally just ordered two Strymon AA.1's lol.
soundshaper
Post by soundshaper » Fri Jun 28, 2019 11:47 am
We've been getting questions about the INTRFX and how it's used. This video explains how simple it actually is, and the flexibility it can add to your setup when integrating eurorack with pedals, synths, drum machines, and guitars.
Thanks for watching!
-Adam
soundshaper
Post by soundshaper » Wed Sep 04, 2019 10:25 am
Just wrapped up a Tips and Tricks video, showing how to use the INTRFX for feedback effects, simple VCA functionality, and chaining channels.
Because each channel incorporates a full blendable FX loop, and switch that swaps the main I/O and FX Send/Return, you can easily create and adjust FX feedback, and control it with CV.
The unit uses three Electric Druid dual VCAs (love these!) for the FX blends, so of course you can make use of these independently for basic VCA duty, both for DC and AC signals.
And lastly, the three discrete channels of the INTRFX can be chained together in series, giving blend amounts at each stage, plus the Pedals/EuroFX modes can be mixed up to integrate Feedback effects into the chain.
Hope this vid was informative. :)
