Disting 3 perpetually restarting itself with SD card
Author Disting 3 perpetually restarting itself with SD card
Risc_Terilia
I was trying to get wavetable VCO going, had it sample playback working with same card but after some messing about with playlists now if I turn on the disting on with the SD card in it just does the start up lights constantly. Any idea please?
Sounds like it's crashing. Wipe the card and start again. Note what it is you change that makes it crash.
Risc_Terilia
Thanks for your help - seems to be something I'm doing wrong with folders for wavetables because it works fine with single files.
Feel free to zip up the card contents and post them here.
Risc_Terilia
The problem is that your waveform files are much too big. There is only enough space for 29000 samples, across all the waveforms. Your first waveform is over 24000 samples by itself.
Risc_Terilia
Ok thanks for all your help!
