Help with Gerber Files/PCB production
Author Help with Gerber Files/PCB production
tardishead
Jason from Free State EFX has kindly put up the Gerber files for his 1Mu version of Ornament and Crime.
They can be found at
O&C Gerber Files
I would like to get a PCB or 2 made up but I have no idea how to order a PCB - what files to use and what options I need to specify in production. Can somebody have a look for me. I have had a look with a free Gerber viewer but a lot of the files seem to look exactly the same. Any help would be much appreciated.
lasesentaysiete
The 3 .zip files contain the gerbers for the PCBs. These .zip files are what the manufacturer will want you to upload. You will probably be asked for the dimensions of each, as well. And 5 is likely to be the minimum order for each gerber uploaded, unless you choose a more expensive "one-off" type prototyping manufacturer.
tardishead
Can you recommend a good PCB house for say a run of 5
lasesentaysiete
pcbway.com
allpcb.com
There are tons more.
